Dropout problems
Hey everyone, I’m currently experiencing dropout problems every time I record. I use the Scarlett 2i2 and am using an adapter to plug into my MacBook Air. I’ve looked through most of the stuff on here and every solution does not work. The mic I am using does not go through and every time I try to record, it drops out. There is an exported recording on here as well but that has never been a problem before. I’ve gone through the manual, and nothing works, any help is appreciated
What “adapter” are you using?
I’m using what I believe is the hdmi to usbc adapter. It’s the rectangle one to the newer iPhone adapter in other terms in case I don’t know what the plugs are called
