Download Problems
Hello,
I’m using a Samsung R40 Plus laptop and have just downloaded Audacity but when I try to open it it says: This app can’t run on your PC. To find a version for your PC, check with the software publisher.
I’m running Windows 10.
Any help would be greatly appreciated.
Thanks,
Barry
You might be running the 32-bit version of Windows. In that case you’ll need the 32-bit version of Audacity.
Hi
I am running the 32-bit version of Windows. How do I get the 32-bit of Audacity?
On this page
Audacity 3.3.1 32 bit installer
That’s it working mate. Thanks for your help. Appreciated
