Download for Single Band Parametric in Audacity not showing in Effects
I’m using Windows 10 with version 2.2.1
I downloaded vst-bridge.dll and single_para_1203.dll to enable Single Band Parametric in Audacity, however, I can’t seem to locate the correct plug-in to copy them into. Under Effects, the application is not there, and despite restarting and relocating the files in “Plug ins” folders within audacity, my efforts are futile.
-B
This is the manual entry for installing VST plugins.
https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html#vst_install
Jury’s out on whether or not they’re supposed to be Dynamic Link Libraries (.dll) or not. I suspect not. That and some VSTs will never install even if you do everything right.
