using windows 8.1 audacity 2.0.5 exe installer
ERROR WHILE OPENING SOUND DEVICE. PLEASE CHECK THE INPUT DEVICE SETTINGS AND THE PROJECT SAMPLE RATE."
My pulldown does not have any of the device settings on the mike pulldown it has= Disable Meter- Horizontal Stereo-
Vertical Stereo= Linar Db- Peferences not like the sample shown I can change the sample rate
Audacity > Edit > Preferences > Devices > Recording > Turntable, Stereo.
Audacity > Edit > Preferences > Quality: 44100, 16-bit.
Try resetting your Audacity like that. The “Turntable” name is whatever your turntable looks like to Audacity. I have a device that looks like “USB Audio Codec”. It could be named anything.
http://manual.audacityteam.org/o/man/faq_errors.html#sound_device
The problem is that audacity does’nt see the turntable
Make sure the computer sees the turntable. Follow all the steps at “Detecting USB and Firewire Devices” in the green box here: http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#flatline .
For setting up Audacity once it sees the turntable, please read Recording with USB turntables or USB cassette decks - Audacity Manual .
