Doesn't detect Yeti mic
I just updated Audacity, and now it doesn’t recognize my Yeti mic, plugged into my laptop via USB. I have been using it for the last four years without a problem. How can I get Audacity to recognize the mic (Rescan Audio Devices has not worked) or undo the update so I can go back to the previous version?
Check your Security Settings t make sure Audacity is allowed to use the mic.
Try Listen To This Device to make sure Windows is getting a signal.
Older versions of Audacity
Post back if you figure it out. The Forum is users helping each other.
Something I did seems to have worked. Thank you for the assistance.
