Does Audacity Use Acceration Tables OR RegisterHotkeys ?
I am trying to improve my automation program for audacity.
I am using powerbasic to send keys to it.
Does Audacity use acceration tables or RegisterHotkey for it’s key functions.
I got my program working, but occasionally having some trouble with timing issues.
I want to be able to directly send messages to Audacity.
Audacity’s batch function doesn’t do vst’s, where my program does vst’s in it’s automation.
Sorry I don’t know the answer to your direct question, but are you able to compile C++ programs from source code? If you are then it may be worth you looking at mod-script-pipe http://manual.audacityteam.org/man/Scripting
