Does any one know?
Does any one know why I Audacity is crashing running the Steinberg, MeldaProduction plugins?
It will run them fine with 1.3.13 beta on vista but with 1.3.13 beta on xp I cant run these plugins.
If you know a fix or something that might help I would appreciate it alot.
Thanks.
Murky Effects.
You could try turning off “Display VST effects in graphical mode” in the Effects Preferences.
Cool thanks. That seems to be working.
Thanks.
