Does 2.3.0 offer portamento effect?
Hi,
Can some one please let me know which effect can be used to make a single pitch slide from one note to another continuously. For example, slide from a higher note to a lower note to create a kind of sad tune.
Thanks & regards,
Lee
You can try [u]Sliding Stretch[/u]. But, if you want to apply it note-by-note that’s not going to be practical.
Thanks for your information. It’s what I was looking for, and works fine for me.
Regards,
Lee
