12:12:47: Audacity 3.7.5
12:12:47: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:47: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:47: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:47: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:47: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:47: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:51: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:51: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:51: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:51: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:51: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:51: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:12:52: Loaded 143 string 2,664062 Kb in size
12:12:52: Project loaded in 31 ms
12:13:10: Using internal LAME
12:13:10: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:13:10: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:13:10: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:13:10: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:13:10: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:13:10: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:05: Using internal LAME
12:14:05: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:05: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:05: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:05: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:05: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:05: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:54: Using internal LAME
12:14:54: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:54: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:54: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:54: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:54: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Impossibile trovare il modulo specificato.)
12:14:54: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Impossibile trovare il modulo specificato.)
Buongiorno. Non so come risolvere questo problema: ad audio fermo e mentre non registro, se seleziono una parte di audio e poi voglio ascoltarlo mi esce questo avviso :
Il tasto STOP è spento e il tasto pausa . Allego la sequenza di errori che ho rilevato .
Grazie
