Distorted audio recording
I use audacity on windows and since I upgraded to 3.4.2 every time I listen to my recording it has these weird warbling sounds mixed in my audio. How do I fix it? I did not have any issues until changing to new version. Thanks.
Does that happen when you play-back in Audacity, after recording but before exporting?
Yes, it does.
Make sure Windows “enhancements” are turned off. Sometimes Windows is trying to “help” and makes the audio worse.
It worked. Thank you for your help.
