Why do numbers appear in reverse?
thank you all
thank you all
because right to left language implementation is flawed, as can be seen from the numbers on the timeline. Getting it to work correctly is very difficult, especially as there are RTL bugs in WxWidgets (which is the GUI toolkit that Audacity uses).
Thank you for your clarification
