Disappearing Audio Track section
I am very new to Audacity. While labeling a project the audio track section disappeared. All that is displayed is the label track. Certain that I hit a wrong key and not knowing how to retrieve it.
I am using Windows 8.1 and the newest version of Audacity. How can I retrieve the audio track section along with right and left audio tracks?
Use View > Fit Vertically to see what tracks you have.
And provided you have not Saved the Project and closed Audacity then you will able to use the Edit > Undo … to step back to where before where you created the label.
Tried both of these things and no results. When I open the project all I have is the label track. Project was saved before closing, but I think I’ll probably have to redo it. Hope not but its not looking good.
Make sure you are using Audacity 2.0.5 from http://audacityteam.org/download/windows .
We do ask you to give the exact three-section version of Audacity from Help > About Audacity. Lots of users say they have the latest version, but they don’t.
If you saved and closed the project with the audio tracks removed, then the audio tracks are gone, short of using data recovery software to recover the AU files for those tracks. That only has a small chance of success.
