Disabling the "sAvE BeFoRe ClOsInG ?" warning prompt when closing the app
i use often use audacity to preview audio file without doing any edits in the software so this warning is 100% useless and therefore wastes my time
that being said thanks for this awesome app hu :slight_smile:
also there apparently was a dedicated section for warning, how/when did this disappear and can it be solved reverting to an older version ?
https://manual.audacityteam.org/man/warnings_preferences.html
Press “Ctrl + Z” before closing. This will “Undo” importing the audio file so there is nothing left to Undo and Audacity will close without prompting to save.
That Save warning is an abbreviation. What it meant to say is "Save Project? Audacity is a Project Editor, not a sound editor. If you didn’t save a Project, then the production isn’t finished.
well that’s somewhat less frustrating but that still implies two presses and one click rather than two (,:
thanks for the input though, weally
