Is it possible to disable iTunes and import from SD card directly to Audacity? Thanks
My SD cards mount on my desktop as a little drive icon. Double click it to open. Control-Click (or right-click) on a song and Open With… If iTunes gets there first, close iTunes. Are you in Yosemite?
I’m not fond of the newer iTunes. It’s harder and harder to do stuff I want.
Thank you very much for the suggestion. I will give it a try.
