I’ve searched for an answer to this, but I haven’t seen it mentioned anywhere; my apologies if I’ve missed it.
When you copy and paste a clip onto the same track, Audacity automatically renames the clip to add a number at the end; e.g., copying “Clip” and pasting it creates “Clip.1”. Do this enough times and you can end up with a dizzying number of digits, like “Clip.1.3.2.1.3” and so on.
Is there a way to disable this behavior of automatically adding numbers to the end of copy-pasted clips?
Thanks.
