Thank you sooo much…for the detailed instructions
WOW, so many new things to learn,
it is not so easy to record as many people think, but its fun to learn
OK, just to review and see if i have understood right:
Soft Clippings, where is this effect?
IS not present in the Audacity effects, unless it has a different name there?
Or do i apply the SOFT CLIPPING through a different tool? Would you mind to let me know which?
Thank you
Then, …The DYNAMIC COMPRESSOR, oh good, it is the one and the same that is built in in Audacity, ( I thought it was external, sorry)
Yes , you are sooo right, it is not an easy tool especially for me, even if I read and re-read the tutorials, I still have not figured out how to make it work with my file, I experimented with different values, but i would just distort the sound, or even decrease the volume
I am guessing you need to know the exact value to choose, in each option, yes, …and that is the reason why I downloaded the Blockfish plug in, yes it is a compressor, and the Endorphine-fish plug in is a booster,
it is easier to just move the buttons in them, while you are listening to your file, but again, even that is difficult, unless u know what you are doing
So,my question:
which would be the best way for you or someone else in the team, to advise me on which values to use in the compressor, to boost my file,
I wonder if i could upload a sample to a website, and then post you the link to it for you to listen to it? would that work?
because if I have to attach it to my post, it i will be too short, barely few seconds, or would that be also enough time?
then about the equalizer, to boost and make my voice deeper, yes, that sounds a really good option
are you referring to the one called EQUALIZATION?
I did just open it up, it is not easy to understand either, I did turn the graphic equalizer on though, to make it easier for me, thats better, shall I just play with the dialer, like every other equalizer? and experiment? Or is it a better way to know?
then last question:
The Gverb, wow, I think that might exactly what I was referring to
I just realized that my Samson mic had a a little sound enhancer software included,
so after recording a sample with Audacity, then having amplified it, then removed the background noise in Audacity, then saved the file as a WAV, after all that, I just tested this Samson effect called Studioverb, (I am sure is the same as Gverb)
I applied it, and it does add some very slight echo that does not repeat itself, just makes my voice a little deeper, but if I am not careful, it becomes distorted
So maybe you or someone else might know how I would know which values I would need to choose in the Audacity Gverb, to just add a little boost and depth, without adding distortion?
Do i just experiment with the values? Or is a better way to know exactly,
Thanks again now
Anna
