Digital File to iTunes
I can convert/record an analog file such as a track from an LP to digital (AAC or WAVE) using Wave Pad but when I drop it into iTunes it won’t play. It does appear in the song listing however. Does any one have any ideas? Thanks.
I don’t use iTunes myself, but there is a section in the Audacity wiki that will probably help: http://wiki.audacityteam.org/wiki/Exporting_your_Audacity_Project_into_iTunes_and_iPod
This workflow tutorial from the manual should help too: http://manual.audacityteam.org/man/Sample_workflow_for_exporting_to_iTunes
Thanks, Steve! Will give it a try.
Doug B.
