Deleting query
Hi all can I get a little help, I’m using version 2.1.3 I need to delete some recordings that I don’t want anymore, and I can’t do it. trying the edit section won’t work. Any ideas.
There is no “Delete Project” command or functionality in Audacity (I’ve always thought there should be - I think I may write a proposal for one)
You will need to use Windows Explorer to the .aup file and the related project data file:
See this page in the Audacity Manual about the structure of Audacity projects: manual.audacityteam.org/man/audacity_projects.html
Peter
