Delete multiple labels
Hi.
A simple 1… cant believe I cant find the answer.
I’ve recorded from an Audio Cassette used Analyse → Silence a few times trying to get the gap dB & time right. I got too many labels.
How do I “clear all labels”, or “all labels from cursor to the end” ?
Thanks!
Version: Latest (2.4.2, on Win1064b)
The quickest way to delete all labels, is to delete the label track - click the [X] in the top left corner of the track.
To delete “all labels from cursor to the end”:
  1. Click on the label track to set the cursor position (MUST be on the label track)
  2. “Shift + K” (select from cursor to end of track)
  3. “Del” (delete)
