Delete a section of an audio file
All I want to do is remove one verse of a hymn I have in an MP3 file. Nothing I try seems to work. I have read and re-read the online manual and I still don’t get it. The section to be removed is from 1:35 to 2:23
You have to select* the section you want to delete. Then apply delete.
*Use the mouse to place the cursor on the start/end of section, then press left mouse button & drag the cursor to select …
The background to the selected section is dark grey.
