Delay when recording VO
I just got Audacity 4 and when i try to record VO there’s an annoying delay. Is there a trick to eliminate the delay? Using a Yeti Blue mike on a Mac.
Have a look at this tutorial.
There’s a lot in there, but the core of the matter is that you need to eliminate latency.
Thank you, I will.
If you can plug the headphones into the Yeti there should not be any delay (latency).
Headphones are plugged into the mike, latency is set to zero, and I sill get a slight delay and a weird sort of reverb when I record my voice.
“audio enhancements” can add reverb.
