default save file type
When I save a file the drop down menu has mp3 in the box, is it possible to change this mp3 default save option to flac? All the best DW.
When you use “File menu > Export > Export Audio…” the format settings will be whatever you used last.
Many thanks for the prompt reply. I exported as flac first time then second time I still get the drop down without flac listed see screenshot. Is there a way in preferences to make flac appear at top of the drop down list? Or to add a keyboard shortcut to open flac file download without the other clicks/steps?
No there isn’t. Just click on “File menu > Export > Export Audio…”
or use the shortcut “Ctrl + Shift + E”.
