debug report
C:\Users\MAHABO~1\AppData\Local\Temp\Audacity_dbgrpt-1660-20170315T191358.zip is my debug report fix this
There is no way we can help you unless you:
a) attach the ZIP file so we can see it - see how to attach files to forum posts
b) tell us exactly when Audacity crashes - after doing what actions
c) tell us your Audacity version (all three numbers - please see the pink panel at the top of the page).
If the problem is a bad setting, you can also try downloading the current Audacity 2.1.2 from http://www.audacityteam.org/download/windows then check (tick) the “Reset Preferences” box half way through installation. On launching Audacity, a dialogue will appear where you can confirm if you want to reset preferences just this once, or not. Say yes to the reset.
In case it is relevant, you might also want to read http://wiki.audacityteam.org/wiki/Windows_10_OS#drivers.
