Debug report audacity
Windows version: windows 7 bit 32
Audacity version: 2.1.1 (.exe)
Here is the problem occuring when I am doing edit parameter for equalization. Also I have attached the bug print short.
A debug report has been generated in the directory.
“c:\users\appdata\local\temp\audacity_dbgrpt-14264-20151214T141820”
Thank you for the report.
This problem is known about and has already been fixed in our source code, but there isn’t any convenient workaround in 2.1.1. If you need to use Equalization in a Chain I suggest you use version “2.1.2 RC1 (for testing)” from http://www.fosshub.com/Audacity.html/.
