data folder won't load upon recovery after crash
Help - It seems my .aup and my Data folder won’t communicate. (Mac - Mojave 10.14.6)
They are both in the same place, one beside the other.
This happened after a crash due to low memory.
It has been a long and arduous mixing process with lots of data and I need this! Please.
PLease help!!! Running Audacity 2.3.2
22:06:37: Audacity 2.3.2
22:06:37: Trying to load FFmpeg libraries...
22:06:37: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
22:06:37: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
22:06:37: avformat not monolithic
22:06:37: Loading avutil from '/Library/Application Support/audacity/libs/ffmpeg_utils.52.64bit.dylib'.
22:06:37: Loading avcodec from '/Library/Application Support/audacity/libs/ffmpeg_codecs.55.64bit.dylib'.
22:06:37: Loading avformat from '/Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib'.
22:06:37: Actual avutil path /Library/Application Support/audacity/libs/ffmpeg_utils.52.64bit.dylib
22:06:37: Actual avcodec path /Library/Application Support/audacity/libs/ffmpeg_codecs.55.64bit.dylib
22:06:37: Actual avformat path /Library/Application Support/audacity/libs/ffmpeg.55.64bit.dylib
22:06:37: Importing symbols...
22:06:37: All symbols loaded successfully. Initializing the library.
22:06:37: Retrieving FFmpeg library version numbers:
22:06:37:    AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
22:06:37:    AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
22:06:37:    AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
22:06:37: FFmpeg libraries loaded successfully.
22:09:11: Error: Could not parse file "/Users/serbancatona/Library/Application Support/audacity/AutoSave/Wirkungsquantum - 2020-04-03 18-17-02 N-785.autosave".
Error: Could not load file: "/Users/serbancatona/Library/Application Support/audacity/AutoSave/Wirkungsquantum - 2020-04-03 18-17-02 N-785.autosave"
22:09:21: Help button pressed: PageName FAQ:Errors_on_opening_or_recovering_an_Audacity_project, releasePageName faq_errors_on_opening_or_recovering_an_audacity_project.html
22:09:21: webHelpPage https://manual.audacityteam.org/man/faq_errors_on_opening_or_recovering_an_audacity_project.html, localHelpPage /Applications/Audacity.app/Contents/help/manual/man/faq_errors_on_opening_or_recovering_an_audacity_project.html
I can’t understand why it won’t load my Data Folder upon recovery. Please help!!!
The last couple of lines of the log indicate the problem:
22:09:11: Error: Could not parse file “/Users/serbancatona/Library/Application Support/audacity/AutoSave/Wirkungsquantum - 2020-04-03 18-17-02 N-785.autosave”.
Error: Could not load file: “/Users/serbancatona/Library/Application Support/audacity/AutoSave/Wirkungsquantum - 2020-04-03 18-17-02 N-785.autosave”
“Could not parse the file…” means that Audacity is not able to understand the data in that file. It is most likely because the autosave file is corrupt or incomplete.
How did the crash happen? What were you doing at the time of the crash? Did you shut down the computer while Audacity was running?
Running out of memory is a very bad thing for any program. It is likely that running out of memory will cause the autosave file to be incomplete. I expect it will be impossible to recover this project.
