Data copied into project is not retained
When I check dependencies and there are .wav files listed, I copy all files into the project. The next time I open the project, the data has not been copied in, and the dependencies are still there. This happens repeatedly, even if I copy the data in again. Why is this happening, and how can I get the data to stay in the project?
I’m using 2.3.3 on Windows 7.
Thank you
