I have a project, approximately 7 minutes total, that has 5 damaged files. The result is that in 5 places, one of the stereo channels is missing, sometimes it’s the right channel, sometimes the left.
Is there a way to copy one channel and paste it into the other to repair the stereo?
I am using audacity 2.0.6 that I installed with .dmg on macbook air, 10.12.2
For repairing small sections, the “Repair Channel” plug-in is probably the better option.
For copying one channel from an entire track, the “Channel Mixer” may be better.
Thank you for the input! I ended up converting stereo to mono, and that created a congruent track - which was actually a blessing in disguise, because it turns out that ACX prefers a mono track. Apparently it’s easier to convert to various formats. Who knew??
The stereo tracks are still damaged, and unless one track can be copied to the other, I think they will remain damaged.
