cuts
I want to Redo the first 12 bars of a recording 0f myself playing. I highlite the first 12 bars of the trck, go to the Edit Menu and select “cut”
RESULT: the first 12 bars are removed but so are the last 12 (maybe 32 bars). Middle section of track remains as desired.
thanks
“Ctrl + Z” to undo the last command.
I’m guessing that even if you undo back enough for the last 12 bars to reappear, those bars will not play. My guess is that you have somehow lost some of the audio data from the project.
Has this project been saved yet? If so, do you see the saved “.AUP” file and its associated “_data” folder?
