Cutin' and Pastin'
It seems when you stop your cursor on the timeline, the time location is printed out on a little strip at the bottom of the work window. Those numbers will not copy and paste as near as I can tell.
It’s paper and pencil time? Somebody posted with a project that requires putting sound duration numbers into a spreadsheet. So far manually. Isn’t this a job for a computer?
Yes Koz, and I pointed out to that user that they could use the labels in 1.3.x to mark the points of interest and then use the File > Export Labels command to export the labels, along with their time markers, to a text file.
In Windows we can open these files with Excel or Word for manipulation or formatting if required - I assume that MACs can do similar?
