Customising the Blank Tool Menu Square
May I offer a suggestion? There’s a blank square in the Tool Menu cluster. Might that become customisable to a user-chosen task or effect? In my case I’d set it to a frequently used macro. Thanks for your consideration.
Unlikely because over time the Tools toolbar is set to disappear with the tools being accessed in different ways.
You can axhieve similar to what you want with a custom shortcut.
See: https://manual.audacityteam.org/man/keyboard_preferences.html#custom
Peter.
Many thanks, waxcylinder - I’ve allocated my macro to Ctrl+0. :slight_smile:
Glad to be able to help Brian,
Peter.
