cursor
Windows 10 64 bit Audacity 2.3.2
What can I do so I can see the cursor ?
Thanks
I have no problem seeing the cursor on either of my W10 64-bit laptops - both ewoth =the releases 2.3.2 and the alpha test build I have for the upcoming 2.3.3
I can barely see it…it is fine all over the screen but when I move it over the track it appears as a thin black line with cross strokes on the top and bottom…ive tried different wave form settings but I still can barely see it
Mine is the I-Beam that you describe - but i’s not exactly “thin” - plus it has a white border around it.
Mine is not…it is fine everywhere else on the window…when I hover over the track it becomes very small and barely visible…is there anything I can do to fix this ? Thanks
Can anyone help me with this ?
Can you post a photo of what you see (a screenshot won’t capture the cursor)?
