Cursor will not move to play
I imported a 44.1 khz 24 bit WAV file into Audacity, but when I hit play, the play button “lights up”, but the cursor will not move, so it won’t play. This happens if I try to play it from the beginning or if I move the cursor to any point in the audio. And it happens with other audio as well, even audio that I’ve played on Audacity previously (chosen from “Recent files”). It also happens if I use Shift +space to try to playback. I tried uninstalling and re-installing Audacity, but that didn’t help. I’m running version 2.3.2 of Audacity on Windows 10 Home build 18362. Thanks!
What is your playback device?
What other software is running?
