Cursor to edit won't work at end of section [SOLVED]
Hi,
Using Mac 10.11.2.
I can’t click a cursor to appear to edit at the very end of a section. I can get the cursor to appear a second or so before the end, but then I can’t click it in closer to edit-delete the last half second of audio. This is a new problem for me, so I’m trying to figure out what happened or what I did differently. I tested this on several different versions of Audacity.
Thank you,
-Keith
PS, I don’t know if this forum allows screenshots, but I will attach one.
It shows a “cursor” at 2:18. I want to create an edit point after that. Nothing happens if I click at 2:18.5.
You have accidentally turned “Snap To” on. (http://manual.audacityteam.org/o/man/selection_toolbar.html#snap) Turn it off.
That was a fast fix! It works now. Thank you Steve!
-Keith
