Hi - I’m trying to use the QuikQuak Crowd Chamber plugin. I’ve put the .dll plugin into the audacity plugin folder, but when I try to enalbe it in the plugin manager, it says ‘failed to register, could not load library’. Anyone got any help? Thanks
Audacity on Windows only supports 32-bit plug-ins. The QuikQuak Crowd Chamber plugin appears to only be available as a 64-bit plug-in.
Thanks - is there any hope of 64-bit plugin support?
