Hi, I would like to select all tracks starting from the focused track up to top or down to bottom. Is there a way to do it maybe with Nyquist? I’ll really appreciate your help,
Thanks,
Juan Carlos
To extend a selection from the current (focussed) track to the first track, you could do something like this in Nyquist:
(defun getfocus ()
(let ((count 1)
(info (aud-get-info "tracks"))
hasfocus)
(dolist (tr info nil)
(setf hasfocus (assoc 'focused tr))
(when (and hasfocus (= (second hasfocus) 1))
(return count))
(incf count))))
(let ((f-track (getfocus)))
(if f-track
(aud-do-command "SelectTracks" :track 0 :trackcount f-track)
"Track focus not found"))
Here it is as a plug-in:
select-above.ny (579 Bytes)
To select down, you will need something like this:
(defun getfocus ()
(let ((count 1)
hasfocus)
(return count))
(incf count))))
(let ((f-track (1- (getfocus)))
(all (get '*project* 'tracks)))
(if f-track
(aud-do-command "SelectTracks" :track f-track :trackcount (- all f-track))
Thank you very much for your kind answer,
Juan Carlos
