I want to set up a project in Windows 10 (MS Visual Studio 2022) to see how the signal is drawn. Can someone tell me how to connect this and run it in debugging mode in MS Visual Studio 2022
hm, I can just build the ALL_BUILD target and then launch that in the debugger.
I need step by step video. Give me please link how do it.
I don’t have a step by step video. Have you followed these instructions? audacity/BUILDING.md at master · audacity/audacity · GitHub
Yes. I try. But many errors
Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19045.
The C compiler identification is MSVC 19.40.33808.0
The CXX compiler identification is MSVC 19.40.33808.0
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe - skipped
Detecting C compile features
Detecting C compile features - done
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe - skipped
Detecting CXX compile features
Detecting CXX compile features - done
Conan: checking conan executable
Conan: Found program C:/python3/Scripts/conan.exe
Conan: Version found Conan version 2.4.1
usage: conan profile [-h] [-v [V]] [-cc CORE_CONF] {detect,list,path,show} ...
conan profile: error: argument subcommand: invalid choice: 'new' (choose from 'detect', 'list', 'path', 'show')
ERROR: Exiting with code: 2
CMake Error at cmake-proxies/cmake-modules/conan.cmake:61 (message):
Conan: Unknown MSVC compiler version [1940]
Call Stack (most recent call first):
cmake-proxies/cmake-modules/AudacityDependencies.cmake:39 (_get_msvc_ide_version)
CMakeLists.txt:223 (include)
Configuring incomplete, errors occurred!
If I do it throughGit - $ git clone GitHub - audacity/audacity: Audio Editor
Compilation goes much further, but many other library errors
Yes. I try. But many errors. help me
