Crashes upon loading via RDP
When I connect to my main computer via Remote Desktop Connection, I can’t get Audacity to start successfully - it crashes with exception code 0xc0000005. I clicked “send” on the diagnostic data generated.
This is with Audacity 3.2.0 on Windows 10 Pro (build 19044.2075)
This is fairly low impact to me since I can just transfer the files to my other computer and run Audacity there, but they are big files and there’s a risk of getting versions mixed up.
This should be fixed in the next release.
Thanks for the response. And thanks for creating this amazing product. The more I use it and the more I learn about its features, the more I am in awe.
FYI, Audacity 3.2.1 was released a few days ago. It corrects a Fatal Error - Exception Code 0xc0000005 problem. You may download it here: https://www.audacityteam.org/download/
