Crashed Windows 10 Audacity 3.4
I have just installed v3.4 and was putting down a guitar track on a part done project in 3.3. It had 7 tracks. It recorded around 35 secs (16 bit as the 24bit record gives full level digital noise). The screen closed , with the Crash Report. If I try to send it I get “Failed to send crash report” I have copied it into notepad and saved it if its of any use.
Fortunately I could revert back to the last saved version AND it had the 35 seconds worth of track I had been recording.
3.4.1 has been released. Give it a try.
I have installed that update and , fingers crossed, it has been stable with that same project with an additional 3 tracks recorded. Thanks for that.
