To get started, here is the log information:
15:34:13: Audacity 2.0.6
15:34:13: Trying to load FFmpeg libraries...
15:34:13: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
15:34:13: Looking up PATH environment variable...
15:34:13: PATH = 'C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Program Files (x86)Common FilesMicrosoft SharedWindows Live;C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;C:WINDOWSSystem32WindowsPowerShellv1.0;C:Program Files (x86)Windows LiveShared;C:Program FilesIntelIntel(R) Management Engine ComponentsDAL;C:Program FilesIntelIntel(R) Management Engine ComponentsIPT;C:Program Files (x86)IntelIntel(R) Management Engine ComponentsDAL;C:Program Files (x86)IntelIntel(R) Management Engine ComponentsIPT;C:Program Files (x86)Windows Kits8.1Windows Performance Toolkit;c:Program Files (x86)Microsoft SQL Server110ToolsBinn;c:Program Files (x86)Microsoft SQL Server110DTSBinn;C:Program Files (x86)PharosSystemsCore'
15:34:13: Checking that '' is in PATH...
15:34:13: FFmpeg directory is in PATH.
15:34:13: Checking for monolithic avformat from 'avformat-55.dll'.
15:34:13: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
15:34:13: Loading avutil from ''.
15:34:13: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
15:34:13: Loading avcodec from ''.
15:34:13: Loading avformat from 'avformat-55.dll'.
15:34:13: Error: Failed to load FFmpeg libraries.
15:34:13: Error: Failed to find compatible FFmpeg libraries.
16:03:15: Error: can't open file 'C:Users1ManOneDrive~ Jazz History & Research ~HUmph - Billy Smith - Tenor Sax Solo_datae00d00e0000467.au' (error 1920: the file cannot be accessed by the system.)
16:03:17: Error: can't open file 'C:Users1ManOneDrive~ Jazz History & Research ~HUmph - Billy Smith - Tenor Sax Solo_datae00d00e0000467.au' (error 1920: the file cannot be accessed by the system.)
16:03:17: Error: can't open file 'C:Users1ManOneDrive~ Jazz History & Research ~HUmph - Billy Smith - Tenor Sax Solo_datae00d00e00002c7.au' (error 1920: the file cannot be accessed by the system.)
System Information:
HP 250 G2 Notebook
CPU: Intel Core i3-3110M 2.4 GHZ
2GB RAM
Here is what happens.
I open Audacity in Windows 8.1. I can try it in the 8.1 view or from the desktop. I get the same results.
I open the file.
I play the file.
After a random period of play, it freezes.
Then I may or may not get the Windows notice of termination.
I flee until I realize that it is the program that is being scheduled for termination, not I. I return to my machine.
I restart the program and eventually have the same thing happen.
There seems to be a correlation between the use of the selective play tools and the crash incidence. It seems like if I just play the file I have no problems. It seems to be a problem when I attempt to play and replay a segment of the file.
