CRASH with Brusfri vst
Dear Developer Team,
Audacity crashes when I load the “Brusfri” vst plugin.
Audacity Version: 2.4.2
OS: Win 10
Process: Load mp3 file, then “BrusFri” → try to play a part of audio to listen the noise → Crash
Plugin was disabled, and enabled, reinstalled, recopied, but it doesnt help. Crash report is attached.
Brusfri version is: 1.1.1
Link:
https://klevgrand.se/products/brusfri
Thank you
Audacity_dbgrpt-13536-20201023T121251.zip (87.8 KB)
Currently Audacity in Windows is 32-bit, so can only run (some*) 32-bit plugins,
even if the computer OS is 64-bit.
[* Not VST3 nor VSTi ]
BTW Audacity does have noise-reduction built-in …
https ://manual.audacityteam.org/man/noise_reduction.html
