Anytime I try to find vst’s and such or manage my plugins from the Effect->Manage or Analyze->Manage or, anywhere else I see a *->Manage, Audacity crashes and brings up a debug report window. This also happens when using Help->Generate Support Data, which thanks to a dry sense of humor is rather amusing.
Any ideas?
Windows 7 Ultimate 64-Bit
Used the EXE installer and tried uninstalling reinstalling once so far.
9:47:04 AM: Audacity 2.1.1
9:47:04 AM: Trying to load FFmpeg libraries...
9:47:04 AM: Trying to load FFmpeg libraries from default path, 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
9:47:04 AM: Looking up PATH environment variable...
9:47:04 AM: PATH = 'C:\ProgramData\Oracle\Java\javapath;C:\Python27\;C:\Python27\Scripts;c:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Broadcom\Broadcom 802.11 Network Adapter'
9:47:04 AM: Checking that 'C:\Program Files (x86)\FFmpeg for Audacity' is in PATH...
9:47:04 AM: Warning: FFmpeg directory 'C:\Program Files (x86)\FFmpeg for Audacity' is not in PATH.
9:47:04 AM: Temporarily prepending ';C:\Program Files (x86)\FFmpeg for Audacity' to PATH...
9:47:04 AM: Checking for monolithic avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
9:47:04 AM: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
9:47:04 AM: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)
9:47:04 AM: avformat not monolithic
9:47:04 AM: Loading avutil from 'avutil-52.dll'.
9:47:04 AM: Loading avcodec from 'avcodec-55.dll'.
9:47:04 AM: Loading avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
9:47:04 AM: Returning PATH to previous setting...
9:47:04 AM: Actual avutil path C:\Program Files (x86)\FFmpeg for Audacity\avutil-52.dll
9:47:04 AM: Actual avcodec path C:\Program Files (x86)\FFmpeg for Audacity\avcodec-55.dll
9:47:04 AM: Actual avformat path C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll
9:47:04 AM: Importing symbols...
9:47:04 AM: All symbols loaded successfully. Initializing the library.
9:47:04 AM: Retrieving FFmpeg library version numbers:
9:47:04 AM: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
9:47:04 AM: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
9:47:04 AM: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
9:47:04 AM: FFmpeg libraries loaded successfully.
9:47:24 AM: Error: Failed to copy the file 'C:\Users\Jesse\AppData\Roaming\Audacity\pluginregistry.cfg' to 'C:\Users\Jesse\AppData\Local\Temp\Audacity_dbgrpt-6472-20151229T094722\pluginregistry.cfg' (error 2: the system cannot find the file specified.)
