I used Audacity to modify the sound effects on the MacOS Mojave. When I’m adding effect, just clicking OK might cause a crash. It happens so often that I have to restart Audacity to edit files. How to solve it? Any help would be greatly appreciated.
Audacity version 2.4.2
os: Mac 10.14.5 Mojave
How long is the show?
When was the last time you restarted your Mac?
How many other things do you have running?
Do you use iCloud or other on-line storage?
Just some effects or all effects?
It happens roughly once every three files. The last time I restarted my Mac was a month ago. Usually I just run Unity, Visual Studio and Chrome. I don’t use iCloud or other online storage.
All effects will be triggered and it seem to be completely random
Try rebooting the computer and see if that helps.
