Trying to use Audacity but when I finish recording my second clip or so of a project, the program crashes. There’s a pastebin of the issue below. I’m using Linux and getting this issue on both the package manager and appimage versions of Audacity.
Is there anything I can do to help fix this problem?
Continuing to use Audacity and I’ve noticed that whenever I click on a project in a way that would make the playhead move past whatever audio I’ve recorded, or when I attempt to play the recording when the playhead is at the recording’s very end.
I should note the AUR package manager version is using Audacity version 3.5.1. I tried using the latest version’s appimage but when I try I get an error reading:
/tmp/.mount_audacipE0DOA/bin/audacity: /tmp/.mount_audacipE0DOA/lib/libmount.so.1: version ‘MOUNT_2_40’ not found (required by /usr/lib/libgio-2.0.s0.0).
