Crash during export multiple
I recorded an LP, the “search for silences” then try to export to I Tunes. I did as AAC files. I am trying to use 2.0.6 version. :confused:
Apple (upper left) > About This Mac. Are you using Version 10.9.5?
Windows 7 PC
What crashes, Audacity or the computer? If the computer crashes, please see http://manual.audacityteam.org/o/man/faq_errors.html#reboot.
Are you using Analyze > Silence Finder… before Export Multiple, or something else?
What happens if you Export Multiple as WAV? You can convert WAV to AAC in iTunes: http://manual.audacityteam.org/o/man/tutorial_exporting_to_itunes.html#conversion.
Thanks Gale. I was able to do it as wave and then to AAC in Itunes. Cool!
If you try AAC again, make sure you have FFmpeg from here http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#ffdown.
