Crackling sound when moving cursor
Sometimes (but not every time I use Audacity) I will get an annoying crackling sound when moving the cursor. It doesn’t show up on anything i export, it’s just related to moving the mouse/cursor. I’m on a Macbook Pro 16" 2019 running Tahoe 26.5.2 (had the problem on earlier OS too), and this problem is both on my just-downloaded version of Audacity 3.7.8, as well as my earlier version 2.4? I don’t think I’ve gotten this crackling sound in any other app, though I might be mistaken. Any ideas?
No idea what it could be - but try to use Audacity as the only application running at that time. Maybe another application reacts with this noise…?
fixed it by just deleting the version i had installed and finding another source. new version works.
What source was that?
