Hi, I’ve spent all morning on a file and it’s close to done. When I try to do any editing now, the program freezes. I can use other files just fine. Tried to attach but it says it’s too big. It’s way bigger than any of my other recordings, even though it is the same length - 10 minutes.
You may be out of luck. First make a backup copy of your recovered project. Can you copy any track to another project ? If so, then you may possibly be able to recover the whole thing with these four (4) easy steps:
- Ctrl+A (Select All)
- Ctrl+C (Copy)
- Ctrl+N (New Project)
- Ctrl+V (Paste into new project) Do NOT copy smart clips.
I hope this helps!
