Corrupt database help
I accidentally saved my project to a local drive that then uploads to my cloud storage. I’m getting the corrupted database others have mentioned. Didn’t want to necro a post so I’m creating another. I downloaded the recovery program but I don’t have any idea how to use it. Could someone give me a hand? It’s an hour’s worth of work I’d rather not redo. Thanks. This should let you download the zipped file. http://u.pc.cd/4QprtalK The one time I don’t export a wav file…
OK. I had downloaded the wrong file. GitHub… First repair failed. Second repair option did create the broken.recovered file but it is blank when I open it. “No row to get a column from. executeStep() was not called, or returned false.”
Am I screwed?
