hello,
i have several records, that were recorded with a device with defective contact.
the audacity wave looks like this:
https://www.dropbox.com/s/7b2vlghkr11dzsi/sound_unterschiedlich.jpg
here is the audio sample: https://www.dropbox.com/s/15fy1nhdurvavip/volumejumps.wav
the sound jumps directly up to a very loud decibel level and jumps back to low level a moment later.
i want to adjust the 2 sound levels, that you can hear no (or nearly no) difference.
i can to this by hand by selecting a loud level range and reduce the decibel level with the normalize-effect.
is there a way to do this for the whole file (more than one hour) to adjust the 2 sound levels to one soudn level?
i tried with compressor, but without success
