Copyright Protected
Hello communaute,
IT’s probably under my nose but I can’t fond the answer, maybe I don’t look at the right place since I’M french speaking. I try to copy my old cassette deck with windows 10 (64B) But I have this messages. “Repartory is potected with copywright” are something like that. Can you help me please? I have join the files with a screen shot…
Thanks!
Marck
You might be blocked from the AppData folder. Try your Music folder or make a new folder inside your Documents folder, etc.
You’re going the wrong way about this.
For instructions on how to copy tapes, have a look at Tutorial - Copying tapes, LPs or MiniDiscs to CD - Audacity Manual
