Copying split delete edits to a different track
I made all these split deletes on these tracks and I’m trying to use them as a template so I can apply these same edits to a different track. All of the tracks are based on the same original track so they are same length. I just need to make these same edits at the same intervals and I’m trying to figure out how to do it automatically. I also thought maybe I could just replace the tracks with the new ones as a workaround but that doesn’t seem to be possible. I think what I’m trying to would be a macro, but I’m not sure. I tried it but it seems too advanced for me right now to use.
Yes it should be possible to do with a macro, and yes it would be quite tricky, but most likely it would not work reliably in current versions of Audacity due to this bug: Unreliable macro processing · Issue #4146 · audacity/audacity · GitHub
